Hi All,
I'm currently AutoVE'ing my 98 Burb and after just running a long, high speed log I have good numbers throughout the logged area of the VE table.
I seem to be very rich at idle....I can smell the fuel and my AFR is around 10.8 to 11 or so.
I'm having trouble hitting some of the low RPM, high Kpa cells but if I apply the log to my VE table I end up with a huge downward spike in the idle area.
What should I do?
Edit: I have the 0411 PCM and using COS3.
The burb is Whippled and I'm using the PLX wideband and 2 bar sensor
