Results 1 to 3 of 3
Thread: ve tuned now kr
    Nov 2006
    Default ve tuned now kr
    i had a tune that was done on a dyno that needed tweaking.
    (my ve table was untouced)
    i had very little occasional kr. after getting my ve inline and
    maf adjusted i`m getting a little bit more kr , but it is not consistant.
    what would make kr in places it wasn`t before?
    there is only 2 spots where kr is predictably present and it`s not always the same amount.
    should i take it back to a dyno or just paste and subract?
    what is the best way to tune the spark tables?
    Aug 2005
    Quote Originally Posted by mr.prick
    If the airmass was greatly changed in those spots, the PCM will reference a different spark value in your high octane table than before. Example, if at 2000rpm/85kPa, you previously had a VE value of 85%, this may correspond to an air mass of .66g/cyl, so the PCM looks up the spark for 2000/0.66. After tuning, that same VE table value might now be 78%. This in turn might correspond to 0.61g/cyl, which in most cases will be a larger timing value. The same physical amount of air is entering the engine, but now the amount of timing (and fuel) has been adjusted.
    Make sense?
    What Justin said... you now get different airmass values which puts you in different places on the spark table than previously.
    I assume you have a map of KR vs DYNCYLAIR_DMA vs RPM, then do this...
    Copy with Labels from this map in the scantool, and Paste and Subtract with Labels in the spark table in the tunetool.
    Also, where the kr occurs, check that your air:fuel ratio is not lean.
  1. Anyone Tuned An FI Setup To 12.5 AFR WOT?
    By therock in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 16th, 2009, 06:29 AM
  2. Never Tuned a Gasser
    By GL4787 in forum Gen III V8 Specific
    Last Post: August 3rd, 2009, 11:22 AM
  3. tuned log scan
    By 2004gmc in forum FlashScan V2 BB Logging
    Last Post: May 31st, 2009, 10:09 AM
  4. My EFI tuned Dmax vid
    By bobo in forum Lounge
    Last Post: November 11th, 2007, 07:07 PM
  5. Can this be tuned out?
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2007, 08:48 AM
