Results 1 to 10 of 15
Thread: How do I unlock the PCM?
    Nov 2006
    Default How do I unlock the PCM?
    When I go to read calibration data i get an error : Bootloader rejected. EFILive could not unlock the PCM.
    I have a feeling HPtuners has it locked somehow. Is there a way EFI will unlock it? As ussual there is no info over at HPTuners on how to unlock.
    Aug 2004
    What does the seed say it is when you try to read?
    Nov 2006
    10:40:17.781: GM operating system: 1271002
    10:40:18.250: Request GM BCC...
    10:40:18.296: GM BCC: DJZX
    10:40:18.765: Request GM VAT Cycles...
    10:40:18.796: GM VAT cycles: 0
    10:40:19.265: Analysing security...
    10:40:19.312: PCM seed is: $02C7
    10:40:19.671: Security analysis complete.
    10:40:19.687: Ready
    Nov 2006
    It also says PCM key is locked with a custom key.
    Aug 2004
    I dont recall ever seeing that Gm os number. Are you using a custom os? If so, then you need to put it back to stock, then use efilive.
    Nov 2006
    Theres the problem. I updated HPTuners reused a custom OS an it charged me another credit. I tried to use a stock tune and used up my last three credits as a vehicle vin tune. After I was charged these credits I went to run the tune then the software said the OS was out of date or something and still charged me the credits.
    In short I am not going to give $99 to get credits to load a stock tune on my car.
    That is another reason I am going to try my luck with EFI.
    Does it sound like my PCM is permenately locked?
    Sep 2005
    You could take it to the dealer and I believe they can flash it to stock, but that's not free either :( unless you have a hook up.
    EDITED: to be PC:x
    Sep 2005
    I don't know if it would work, but you might try to just do a FULL write to your PCM with a stock base EFILive tune. Might write over your HPT custom OS.
    Aug 2004
    That wont work. He needs to put it back to stock using the hp cable he locked it with.
    The Dealer wont be able to do it.
    If he knew the exact key, then he could manually type that in, But i doubt the hp crew would do that for him.
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Question is why in the hell is there a need to lock the friggen tune in the first place? It's his tune? He paid for it? Seems dumb to me but I'm old and a lot of crap is starting to look dumber as I age.
    Elmer
  1. How can I unlock a PCM
    By imtduncan in forum Gen III V8 Specific
    Last Post: February 19th, 2009, 08:12 PM
  2. Can't unlock pcm
    By red12secz28 in forum Duramax LB7
    Last Post: November 30th, 2007, 02:29 AM
  3. ECM Lock and unlock
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2007, 02:59 AM
  4. Unlock the PCM
    By ASSAMI in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 15th, 2007, 05:49 AM
  5. TCC Unlock Problems
    By Rontune in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 7th, 2006, 09:46 AM
