Results 1 to 10 of 11
Thread: '98 LS1 Rev Limiter...
    May 2006
    Default '98 LS1 Rev Limiter...
    Hey Guys,
    Like the title says, I have a '98 Camaro automatic with a 382 cid engine. I have set my rev limiter to 7200 and the car is hitting the limiter at 6800. WTF! Am I over looking a table or something. I've changed all the rev limiter tables and it still does the same thing. Is there something up with the '98 OS causing this? If this is the case, can I update to a later OS? Any help is greatly appriciated!
    Thanks, Coleman
    Jan 2007
    Not 100% but I'm pretty sure you could put an 0411 PCM in it from a 99+ vehicle.
    Search for threads regarding the 98-01/02 PCM swaps.
    Here's one which may be of interest.
    http://forum.efilive.com/showthread....&highlight=pcm
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Yea, if you have a little time and want to upgrade to a COS, check out ChipsByAl's awesome 98-> 02+ PCM tutorial.
    May 2006
    Thanks guys for the response. So are ya'll saying that is what my problem is? Having a '98 ECM.
    Lifetime Member Doc's Avatar
    Oct 2005
    What tranny are you running in this setup? What rear end, tire size? If you are running an electronic transmission and are trying to use EFI Live to control it, then you need to have the rpm and speed settings just right. If this is the case then it would seem that you need to lower your speed a few mph.
    www.efialchemy.com
    www.greatamericancarwar.com
    Jan 2007
    Seems from everything I've read here and on other forums, the 96-97 PCM is the red headed step child of PCM's....if so, the 98 is his twin brother!
    Howard
    DUCT TAPE.
    Apr 2007
    I have a 98 C5 with an A4 and I have no problems with the rev limiters or the WOT shift points---If you have EFILIVE--send me your file and let me take a look---I have 50-100 hours of tuning into this car as I use it as a test vehicle and have taken it to the track many times tblu92@sbcglobal.net
    May 2006
    change tables
    B3303,B3306,B3330,B3331,B3322,B3323.
    Make sure you changed all those tables.
    Check your abuse managment table too.
    May 2006
    Thnaks guys! I will double check everything ya'll have suggested and let ya'll know what I find!
    -Cole
    May 2006
    I checked all the tables yall suggested, and still no change! Is this ECM not cappable of a reving higher than 6800 RPMs? Would a certain SES code be causing this problem? Maybe even a sensor or something like that?
    -Cole
  1. Rev limiter help
    By Badmire68 in forum Gen III V8 Specific
    Last Post: January 17th, 2008, 10:53 AM
  2. 97 C5 Rev Limiter ?
    By Kool C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2007, 12:28 PM
  3. rev limiter
    By CWR in forum Vortec V6/V8 Specific
    Last Post: July 4th, 2007, 05:40 PM
