Results 1 to 10 of 13
Thread: Loaded Custom OS: 03Z06..starts/dies after 1 sec
    Nov 2004
    Default Loaded Custom OS: 03Z06..starts/dies after 1 sec
    I loaded Custom OS 0203003 into my 2003 z06. The car starts and then dies. I retraced all my steps to make sure that I performed than correctly. I checked the VATS (theft) settings and they all seemed to be ok. I did a comparison of files and the only things that were different were the values changed per page 7 of the install manual. I performed a search I'm not getting anything that I can use. Any help would be appreciated.
    Jul 2005
    Post your tune. Try first flash for operating system and a second flash for tune only.
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Nov 2004
    Quote Originally Posted by purrvert
    I did flash the OS first and then the tune only. Please see attached for the tune. Thanks in advance for help.
    Quote Originally Posted by Earl H
    Try changing the 35 to 50kPa / 400 to 1200rpm main VE table by +3%, if it still runs 1 sec and dies....add another 3%.....had that problem before.
    Set the open loop multiplier to 1.00 to begin
    Lifetime Member Doc's Avatar
    Oct 2005
    When you go key on, and connect with the scanner is the VIN correct?
    www.efialchemy.com
    www.greatamericancarwar.com
    May 2006
    did you fix it yet
    2002 ws6 stock short block
    GMPP cnc LS6 Heads 11.4:1 cr
    .576 i .581 e 116 lobe
    D1SC @ 10#
    723 rwhp 654 rwtq on E-85
    May 2006
    Quote Originally Posted by onfire
    as stated A0008 should be 1 not 2 if it is any higher than 1 it will command more fuel you are commanding twice the fuel with it set at 2 you should read the tutorial it appears you have other issues in there that will need to be addressed
    D1SC @ 10#
    Nov 2004
    2 ended up being the default value. The tutorial said it should be at least 1, therefore I didn't change it. I will be trying the recommended steps 1st thing in the morning to see if they fix the problem. Please list others if they come to mind. I will be trying all of them.
    May 2006
    the tutorial explains the values that load with it are not sane values they are out of range when you first open the .tun file it will open a window stating that there are calibrarions out of range these must be put in range for the vehicle run properly if you click on the cal# it will have on the upper right the min. and max values
    D1SC @ 10#
  1. Car starts but won't stay running
    By brianjw4 in forum Gen III V8 Specific
    Last Post: April 10th, 2009, 10:37 AM
  2. Help: Loaded a COS but can't load Cal
    By Andrew in forum Custom Operating Systems
    Last Post: August 15th, 2007, 09:43 AM
  3. starts for 1 sec and then dies
    By Cablebandit in forum Custom Operating Systems
    Last Post: April 8th, 2007, 12:32 PM
  4. Confirming tune was loaded properly
    By kbbrett in forum General
    Last Post: January 24th, 2007, 07:30 AM
  5. 01 to 02 conversion - no starts
    By Max Power in forum Duramax LB7
    Last Post: June 22nd, 2006, 02:00 PM
