Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Trouble loading 2002 OS in 1999 PCM
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Default Trouble loading 2002 OS in 1999 PCM
    I have V1 Commercial and upgraded to V2. The V2 is up and running and I transferred the licenses to the V2.
    I am trying to upload a converted 2002 Vette OS to my 99, I believe I should hit "Program PCM with currently loaded Operating System and Calibration" to do this, however it is not selectable (greyed out)...
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Sep 2005
    My V2 has done that a time or too. Doesn't seem to recognize its a commercial version. Try unplugging and repulging everything, maybe even close down the software and restarting it. Usually works for mine.
    Jul 2006
    Yep that worked...
    Thanks kbracing96
    Car even starts with the New OS...
    had to reset the oil life after the update
    But now I have a DTC 1336 Crank Position CKP System Variation Not Learned
    Maine USA
    Sep 2005
    Just use the scan tool bidirectionals to do the CKP relearn.
    Jul 2006
    That was not so bad, did the relearn (it stumbled at about 3800-4000 RPM and the DTC is cleared).
    Took it out and did about 40 miles no codes and drives fine...
    So next is the Cal only flash with OS5?
    I am getting close to wrapping this thing up.
    Maine USA
    First do a full flash of COS5 (02020005).
    Then do a cal only flash from your saved 2002 OS (12212156).
    Then edit the out-of-range values to some sane value (or to max-1 for some).
    Jul 2006
    LOL damn I gotz it backwards you get me about once a year there Joe doing something ass backwards fortunately i did not try to merge em yet
    Maine USA
    Jul 2006
    OK not getting anywhere...I did various combinations
    Base 2002 (full OS load) with the COS 5 (cal only) loaded cal only goes into reduced power mode on start up
    Loading the COS 5 (full OS load) first then the 2002 tune cal only yeilds no start.
    Maine USA
    After a quick look, some comments on the second tune:
    - looks like MAF is enabled, increase C2911.
    - B3547 is very rich at idle, and lean at high MAP values.
    - B5913 has too much advance for boost, seems to me.
    - C6301 doesn't look right for 2 bar MAP sensor (but I'm not sure).
  1. Trouble loading pid selection to BB
    By Picto in forum Black Box Logging
    Last Post: November 15th, 2010, 05:00 AM
  2. 1999 LQ4 - Suggestions
    By Cougar281 in forum Gen III V8 Specific
    Last Post: March 28th, 2010, 05:16 PM
  3. Trouble loading DSP5 Tune
    By Dmaxx 02 in forum Duramax LB7
    Last Post: September 14th, 2009, 07:12 PM
  4. 1999-2002 Camaro wanted
    By emarkay in forum Lounge
    Last Post: March 25th, 2007, 02:30 PM
  5. Trouble loading V7.31 after system reinstall.
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2006, 08:40 AM
