Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: Trouble loading 2002 OS in 1999 PCM
  1. #11
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    The intent is to use the Nitrous part of the OS on a NA car.
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
  2. #12
    Jul 2006
    Ok after following the tutorial to a T, it starts but now I have DTC 0300 Misfire issues, idles horribly and stubbles when revved...will post current tune. in a few minutes.
    Maine USA
  3. #13
    Jul 2006
    Here is the current tune I am trying to use...
    http://www.retrorelics.net/jim/Board..._02OS_7May.tun
    Maine USA
  4. #14
    Beer,
    - Enter values for those out-of-range tables/parameters.
    - For NO2, use A0015 to richen, and A0016 to retard.
    - Closed loop is enabled and MAF enabed... is this how it was running prior to going to COS5...?
    - During idle/warmup, open loop AFR will be very rich, but at high map values it will be too lean, see first pic; should look more like the second pic.
    - Post a few logs.
    Joe
ID:	1635   Click image for larger version.
  5. #15
    Jan 2006
    sent you an email
  6. #16
    Jul 2006
    I think I have another issue as well, I think I knocked the MAP hose off running a FPSS harness, let me check that as I loaded a tune that worked previously and the MAP at idle is 40-70 kpa and very erratic.
    Maine USA
  7. #17
    Jul 2006
    Well this sucks, pulled the intake off, and the hose was fine as well as everything else...something is just not right...
    Maine USA
  8. #18
    Jul 2006
    Beer,
    - Post a few logs.
    Joe
    Joe yes it was running fine with the CL and MAF enabled pre COS5
    Maine USA
  9. #19
    Quote Originally Posted by Beer99C5
    If you copied your VE and and IFR tables (and all the other tables)...
    then it's probably due to either (or both) of:
    - the out of range values need to be made sane (the displayed value is the max, but the actual value is out of range; enter max-1 or some sane value, save and do cal-only flash).
    - B3647 is very rich at low RPM (something like AFR 9)... this table you have to make look like the pic in my earlier post... flat at low/mid MAP, and then ramping up to high MAP so that it's sufficiently rich when throttle is wide (and MAP is high).
    "...I hate when that happens..."
  10. #20
    Jul 2006
    I will that next Joe, I am bolting up the intake (was not the MAP hose, as I had hoped)...
    On the up side my intake/fuel rail removal/install skills are getting quicker :lol:
    Maine USA
  1. Trouble loading pid selection to BB
    By Picto in forum Black Box Logging
    Last Post: November 15th, 2010, 05:00 AM
  2. 1999 LQ4 - Suggestions
    By Cougar281 in forum Gen III V8 Specific
    Last Post: March 28th, 2010, 05:16 PM
  3. Trouble loading DSP5 Tune
    By Dmaxx 02 in forum Duramax LB7
    Last Post: September 14th, 2009, 07:12 PM
  4. 1999-2002 Camaro wanted
    By emarkay in forum Lounge
    Last Post: March 25th, 2007, 02:30 PM
  5. Trouble loading V7.31 after system reinstall.
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2006, 08:40 AM
