is there a way to turn off Stabilitrak some where. Its getting rather annoying with every hard slow turn i make it shuts the motor down. Pulling the fuse dont help and i dont want to turn it off at the gear shifter every time i start it up.
It can only be turned off with the switch or a malfunction of the system. The system defaults to ON at key on. A malfunction would put the vehicle in an unsafe mode. No ABS would be likely.
Al
pulling the fuse shuts down the functions of abs, traction control, stabilitrak and parking brake sensor. i was just hoping there was somthing i have been missing in the tuning.
2003 Silverado SS
12.95 @ 103 n/a on #3 408
2006 TBSS 14.3@97(hers)
2006 Ford F250 Lariat Powerstroke 14.2@89
1974 Toyota FJ40
Yea, the TB SS ST/TC can only be turned off by holding the button on the shifter for ~5sec.
OR, there is a writeup on TrailBlazerSS.com where a guy wired a switch that sends a pulse signal to the ST/TC wire and disables them both on startup. Pretty simple but it works.
