Results 11 to 20 of 27
Thread: Use MAF for off boost/2 Bar SD when in boost
  1. #11
    May 2006
    i believe that if you command stoich it allows the LTFT to become active thus throwing off your auto ve
    yea what he said
    2002 ws6 stock short block
    GMPP cnc LS6 Heads 11.4:1 cr
    .576 i .581 e 116 lobe
    D1SC @ 10#
    723 rwhp 654 rwtq on E-85
  2. #12
    Jan 2007
    Correct me if I'm wrong Joecar....after we went through this stuff a while back with my autoVE wasn't it understood that even commanding 14.70 is no good as that equals EQ 1.00?
    Mine is set to 1.0059 EQ. which equates to around 14.58 AFR.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  3. #13
    Howard,
    Good point...
    that was because your B3601 was set to 14.68... showthread.php?t=5144
    (that's why it's better to use EQ units instead of AFR units).
  4. #14
    Nov 2004
    Howard,
    Good point...
    So 3601 and 3647 must be different to prevent the pcm from slipping into semi close loop?
  5. #15
    Oct 2006
    As Redhardsupra points out elsewhere, the commanding stoich & disabling pe step is no longer necessary when using a wideband. These steps are only an offshoot of using trims to tune.
  6. #16
    Quote Originally Posted by Earl H
    That's correct.
  7. #17
    Nov 2004
    So what should we set it up to command 14.7 or 14.5? Once BENs are at ~ 1.0, then what?
  8. #18
    If you command 3% under or over, it should be fine.
    When BEN's are close enough to 1.00, then you can command stoich if you so wish...
    but do keep the high MAP columns of B3647 rich (12.6 or what you want at heavy load).
  9. #19
    Default Semi-open loop
    Here's what semi-open loop looks like (look at AFR_WBOS1)...
  10. #20
    Nov 2004
    Can you guys tell me what you think of these two files? BENS close enough. Commanded is at 14.6 on these passes. I haven't had a chance to adjust.
  1. What AFR in Boost?
    By zapp168 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 24th, 2007, 01:03 AM
  2. Boost and EGT's
    By minytrker in forum Duramax LB7
    Last Post: February 14th, 2007, 03:41 AM
  3. Can you log boost?
    By AustinL911A in forum General
    Last Post: January 5th, 2006, 07:55 AM
  4. What happens when you go into boost?
    By hpcubed in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2005, 05:49 PM
