Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Use MAF for off boost/2 Bar SD when in boost
  1. #21
    Quote Originally Posted by Earl H
    Can you guys tell me what you think of these two files? BENS close enough. Commanded is at 14.6 on these passes. I haven't had a chance to adjust.
    I'll hve to look after I get home tonite.
  2. #22
    Oct 2006
    There is a lot of crud in them logs that you cant easily filter out. When decellerating during a log you should back your foot right off the pedal quickly so you can filter out the rich spikes that are caused. By letting your foot off slowly you can accumulate richer readings in your log file which will throw your BENS out.
  3. #23
    I agree with 5.7ute...
    The rest of the BEN's look good.
    Are you using then LC-1 to simulate HO2S11...?
    You might try to program the high voltage higher by 0.050V and the low voltage lower by 0.150V to bring it closer to HO2S21.
  4. #24
    Jul 2005
    LTFT has to be turned off in order to get BENs in line. Somebody correct me if I'm wrong!
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
  5. #25
    Quote Originally Posted by purrvert
    That's correct... and a few other things also.
  6. #26
    Nov 2004
    Why not just disable trims? {B3801} and {B4108}
  7. #27
    It will still go into semi-open loop mode (for stoich cells in B3647)... or at least mine seems to.
  1. What AFR in Boost?
    By zapp168 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 24th, 2007, 01:03 AM
  2. Boost and EGT's
    By minytrker in forum Duramax LB7
    Last Post: February 14th, 2007, 03:41 AM
  3. Can you log boost?
    By AustinL911A in forum General
    Last Post: January 5th, 2006, 07:55 AM
  4. What happens when you go into boost?
    By hpcubed in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2005, 05:49 PM
