Results 1 to 9 of 9
Thread: flashing MIL?
    Apr 2007
    Default flashing MIL?
    This has been a minor issue ever since I put in my cam in last year (240s duration 111 lsa) - 2001 C5 Corvette. The idle lope is pretty choppy, and this is known for setting off a false misfire detection.
    I have the P0300 code set to "not reported" on C6001, and "no MIL" on C6002.
    During periods of long idling only, the MIL flashes. No codes are reported (through the dash DIC) when this occurs, so I assume it's still the misfire detection having some effect. If I rev it up a little bit over idle so it smooths out, the MIL light goes out.
    It doesn't bother me so much, as I know what it is...but anyone who looks inside the car while it's idling inevitably asks me about it.
    I looked at the misfire parameters and tables. If I set C6602 to a high enough temp that misfire would never be tested for, will this work, or would it be unwise to do so?
    Any other suggestions/possibilities?
    Also, if it could be something other than a misfire detection setting this off...why can't I pull up a code for it?
    Thanks,
    Tom
    Aug 2005
    Have you adjusted tables C5621 - C5627?
    Apr 2007
    Quote Originally Posted by dc_justin
    No, I have not.
    Should I have, and if so, is there any info on how to properly do so?
    Aug 2005
    If you're having misfires at idle, I'd start with raising the idle misfire value. This allows for a longer period of time between cylinder events before the PCM determines that a misfire has occurred.
    Apr 2007
    Thanks, I will try that.
    I guess the thing I still wonder about though...if the misfire code is set to no MIL and not reported, why does it still flash the light?
    Quote Originally Posted by Thimble
    Hi Tom,
    You could also try increasing C5606 to the RPM where the cam smooths out.
    That way the misfire tests won't run when the engine is idling under that RPM.
    Also to help deterine that is is in fact a misfire code (even though it is probably false misfire due to the cam), try logging the following PIDs:
    GM.MFTOTAL,
    GM.MFFAIL,
    GM.MFPASS,
    GM.MFCYLxC (where x is 1..8)
    Apr 2007
    That seems a better method than what I was thinking. I will definitely give that a try.
    Thanks a lot for the quick replies!
    Oct 2003
    Tom,
    Not to pile on here, but if you get a good VE tune done the cam will really smooth out at idle and transiton off idle much better.
    You have plenty of cam there to sound snorty but it can be smoother I bet.
    Bruce
    PowrMax Performance
    100 mm PowrMAF
    Apr 2007
    If I make it any smoother, I will want a bigger cam.
  1. E38 Flashing tips.....
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: June 2nd, 2011, 01:15 AM
  2. Flashing ECM Alone?
    By Nemo in forum General (Diesel)
    Last Post: April 12th, 2010, 08:18 AM
  3. Flashing different OS?
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2010, 09:00 AM
  4. re-flashing
    By s10mods in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2007, 09:39 PM
