Results 1 to 9 of 9
Thread: Confusing EFI Live data...
    Default Confusing EFI Live data...
    Ok, my buddy has a 2001 Dmax 2wd.. it says it has 3.73s by the RPO.
    but i found this in the TCM
    and this in the ECM.
    Whats up with that?
    anybody?
    Dec 2005
    That's normal.
    SWB Ex Cab K2500HD 04.5 Lt/Amsoil B2B/ARE Tonneau/BedRug/Evans NPG+/LT235-85R16/Putco White-Out/VR-Straps/HIR 9011&9012/Mag-Hytec Diff/Cat delete pipe/Built Trans/Sun Coast 6sp/Transfer Case Brkt/SD Rods/Racor Pre/Ppump/OEM 3" Ext.
    EFILive Distributor Trippin's Avatar
    May 2004
    Yep normal for the TCM to say 4.11.
    As far as the 3.7 in the ECM, you may expand the number of places to the right of the decimal using the +.00 command in the upperish right corner.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    So its normal... thats kindof weird.
    why would it have 4.11 in the TCM?
    Does the TCM not use that value for anything?
    May 2004
    The TCM does use that value as others have changed it and found their shifting change as well.
    As far as I know most leave it at 4.11.
    www.socaldiesel.com
    I don't know the exact reason behind it, sometimes these things are only used as reference.
    Perhaps in this case it was something that was overlooked in the early days of the TCM calibrations development, I don't know.
    Ok thanks guys!!
    Senior Member lakingslayer's Avatar
    Dec 2005
    It changes the shift points a little but it's really not important IMHO. I think the TCM uses it in part of it's shift speed calculation somewhere. I have mine set to 3.73 in both the TCM and ECM. Works fine for me.
  1. What types of computers will the EFI Live data tuning work on?
    By Gusdieselboy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 28th, 2009, 03:43 AM
  2. Tuner not correctly following live scanner data?
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 06:30 AM
  3. No live data on EFI scan tool
    By Drummer in forum FlashScan V2
    Last Post: February 18th, 2008, 12:05 AM
  4. L92 Data log
    By etmotorsports in forum Gen IV V8 Specific
    Last Post: January 26th, 2008, 05:04 PM
  5. Live tuning for RFI-Live??
    By Bob's Garage in forum General (Petrol, Gas, Ethanol)
    Last Post: September 14th, 2005, 06:27 AM
