Results 1 to 5 of 5
Thread: '00-'01 van tune?
    Apr 2007
    Default '00-'01 van tune?
    Hey guys,
    Im about to put a 411 in my 96 k1500 L31. I dont have it in yet so i cant hook up and pull the tune. But i'd like to start playin around with my EFIlive setup. Just wonderin if anyone can hook me up with that stock cal file.
    I'm not a total nube to the tuning world but i am new to this specific setup. (Had Jet DST)
    Thanks alot.
    my email is : paladolightbringer@hotmail.com
    Jan 2007
    This is the one I'm using.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Apr 2007
    Default many thanks
    Thanks alot.
    Lifetime Member N0DIH's Avatar
    Jan 2006
    I am at a loss to find where to get the 80 pin connectors for this swap, any recommendations?
    Quote Originally Posted by truethinker
    Hey guys,
    Thanks alot.
    Aug 2006
    Try EFIConnection.com or your local U-Pull junk yard. The color of the little plastic piece denotes where the indexing tabs are. You can use other color connectors and just trim off the indexing tabs. Then paint the aluminum body of the connector Blue or Red for clarification.
  1. Replies: 5
    Last Post: August 5th, 2008, 01:35 PM
  2. Tune VE and MAF tables or leave VE stock and tune MAF only
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 4th, 2008, 07:05 PM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 01:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 11:04 AM
