Results 1 to 10 of 18
Thread: Will not start No guages, nothing
    Feb 2007
    Default Will not start No guages, nothing
    The car is a 1999 Trans Am
    Well i flashed a tune in last week. Havent been able to drive the car much, it has no interior in it, just got finished caging it. I fired the car today and moved it around. Then put it on the lift to hand the exhaust. After that was finished i jumped in it turned the key and it started to turn over. The starter stopped and the gauges all shut off. The car has power, the interior lights are functioning properly. What could be going wrong?
    The other thing i noticed that had never happened until after the last flash, the gauges when you turn the key on would completely peg to the right and then settle down to the cars normal state.
    Anyone have any ideas?
    I would try re-flashing it again. It could also be an issue with the VAT's system. Sometimes the PCM needs a swift kick in the rear.
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Feb 2007
    well i will try that tomorrow. Its just odd because nothing works, yet my power antenna goes up, yet i dont even have a radio installed. Damn electrical gremlins. I surely hope you are right.
    Easy enough try and I have seen this before. For some reason with the C5's I'll get the engine to start and have no gauges. I'll reflash the tune and it works. The VAT's has also been known to cause a simliar issue. Try the reflash first.
    1-954-703-5560
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    I find about one in ten flashes result in no guages (C5s) always works second time.
    PowrMax Performance
    100 mm PowrMAF
    Feb 2007
    The odd thing is that after the flash it had been starting and running fine for a few weeks. Then the only change was to put exhaust on it and now its dead.
    Oct 2003
    That is different, then-
    PowrMax Performance
    100 mm PowrMAF
    That's what you get for modifying your car! LOL~
    1-954-703-5560
    Changing exhaust seems to cause a whole bunch of electrical problems...
    Might be a symptom of weathered/dirty/corroded engine grounds...
    Feb 2007
    See this all started when i forgot to top off the oil in my headers!
  1. E38 No Start
    By VEGASROBBI in forum Gen IV V8 Specific
    Last Post: July 26th, 2009, 11:15 AM
  2. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  3. Where to start.
    By biglope in forum Custom Operating Systems
    Last Post: November 6th, 2008, 05:38 PM
  4. Cold start great but warm start sucks."Idle
    Last Post: October 26th, 2008, 12:22 AM
  5. Dashboard guages issue
    By azzhauler in forum FlashScan V2 BB Logging
    Last Post: May 30th, 2008, 06:18 AM
