that timing drop only appears only from a dead stop off idle launch...(frame 47)...
if i brake stall it up to say around 1500 and then launch it doesn't drop as much...i believe it slows the car a bit at only this spot...
my questions are these...
will raising the timing just in the cells (dyn cyl air vs rpms)that match the logs help this drop???
would it be located in the base spark in gear tables or high/low octane tables as well???
