Results 1 to 10 of 15
Thread: Serious problems again - please help
    Lifetime Member Boost's Avatar
    Dec 2006
    Default Serious problems again - please help
    I just locked up a PCM again. I have tuned this truck succesfully 5 times already, and I don't understand why this is happening.
    For those that are browsing this forum, I have had amazing success with EFILive, and have tuned 15 vehicles with no problems and great results.
    So it must be something that I am doing wrong.
    It's a 2006 Silverado with a 5.3 "T" motor. He went back stock for a while due to the fuel prices, and wanted his tune back for the weekend. I made sure that my laptop as well as the truck battery is properly charged, and turned on the ignition. (all accesories off, of course). Opened his tune file and "checked status". Got an ok (green check mark), so I went to write. It started, but never made any progress. When I saw the red letters and reflash failed I got worried. Shut the key off, waited for the 15 second countdown. Truck will not start. Tried to reflash stock, no response. tried unplugging the PCM (which works sometimes), but it still won't start. ???
    I know that I did not wait very long (maybe less than 30 seconds) after I turned the ignition on, but if the modules were still too active to tune, it shouldn't give me the green check as if it's ready to go. I am sorry that I am having these problems, but it's really bad because now the guy is without his truck and I have to come up with a PCM. I am going to endanger my job if I warranty any more controllers. Please help, what am I doing wrong??
    8.7 @ 84 (1/8 mile) bolt-ons
    Jan 2004
    What exactly is the error you receive when you try and reflash it?
    Jun 2005
    Was it a full re-write or just a partial flash?
    Dec 2006
    It does not say "warning full flash" if that's what you're referring to. It's a simple power tune and gear adjustment that I've done many times before.
    And the error message said something about the flashscan not communicating (I checked all the cables of course and the cigar lighter fuse).
    This is after it initially said re-flash failed. Help me... :(
    Dec 2006
    In my desperation I installed another PCM that is from a crashed '06 truck with a 5.3
    It says "incorrect VIN". I suspect this is because the donor truck had a "T" motor, not a "Z" motor (flex-fuel). I am so screwed ! Any ideas?
    Quote Originally Posted by Boost
    After a failed calibration only reflash you can check the state of the PCM:
    Turn on the vehicle's ignition, wait 20 seconds.
    Connect the FlashScan cable to the vehicle but not to the PC.
    On FlashScan V1: observe the orange OBD LED.
    On FlashScan V2: observe the orange LED second from the right.
    If the LED flashes at exactly 4 times per second always, the PCM is in deadpoll and is waiting to be reflashed. The vehicle will not start in this condition. You should attempt a cal-only reflash to recover.
    Dec 2006
    Thanks for your response. I freak out way too much when stuff like this happens, but it's embarrasing when I immobilize a vehicle. The laptop has it's own batteries, I never power it from the vehicle (cigar lighter or auxilary outlet). The only connection to the vehicle is the OBDII port, I don't know if it draws from there since the Tech2 does get it power from there. Anyway, I will try to do what you said.
    We put a new PCM in the vehicle, and tried to program it with the Tech 2. It fried the new PCM with normal GM programming !!!! This can mean only 2 things:
    1) There is a problem with the truck - BUT it has no aftermarket stuff, and only the radio was changed since the last succesful flash.
    2) There is a problem with the Tech2 (we've had problems with the CANDi modules sometimes which enable high speed communication). That would be a total co-incidence, being that the EFILive failed and then the regular GM programming as well.
    It is more likely that one of the modules got "pissed off" the first time, and is now frying any new PCMs that are installed. (??)
    We checked communication with all modules and everything seems normal except a BCM message (something about data link if I remember correctly).
    We have had non-responsive PCMs before with the same message in the BCM. Could I have upset the BCM and it's now killing the PCM? Does this even make sense?
    So in theory if I didn't wait long enough to write after I first turned on the ignition, and the modules were still waking up (active), and one of them (possibly a high speed one) got mad, is this possibly causing destroyed PCMs?
    Because the only other logical answer would be a coincidence of the EFILive and the Tech2 freaking out at the same time.
    Is the BCM easy to get at? Can you unplug it while the reflash is taking place? It may be an intermittent comms fault in the BCM - that could interfere with a programming session.
    Or better still remove the PCM and reflash it using a bench harness, see this doc for wiring/pinouts required for a bench harness:
    http://download2.efilive.com/Tutoria...20Tutorial.pdf
    If you were only performing a cal-only reflash with EFILive then the PCM should be recoverable once the problem is rectified.
    Unfortunately when Tech2 reflashes it does a full flash, so if something fails (BCM shorting bus to ground for example) during the Tech2 reflash it is more likely to permanently kill a PCM.
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    I would check out the new radio and wiring, as that is the only thing that was changed since the last flash.
    Dec 2006
    Thank you all! With the information Paul provided we were able to diagnose the problem. Everything is back to normal and there is no damage. There was an aftermarket I-pod adapter in the vehicle, and the factory radio was from an '04. We were able to save all the PCMs and return them, and the truck is now running perfect.
    Electricity is like math, just because we may not understand it, it is still logical and consistent. This was a great learning experience, although a bit nerve wrecking. As usual, the fault was not in EFILive, but due to aftermarket accesories.
    Thanks a million for outstanding customer service and tech support !!!
  1. Having some problems...
    By CisforCookie in forum EFILive V4
    Last Post: July 7th, 2009, 02:11 PM
  2. Help problems......
    By VACARELLAB in forum Duramax LB7
    Last Post: April 14th, 2009, 12:16 AM
  3. V2 problems
    By GAMEOVER in forum FlashScan V2
    Last Post: January 17th, 2009, 01:05 PM
  4. 2 problems
    By 1fastgto in forum Gen IV V8 Specific
    Last Post: December 26th, 2008, 05:27 AM
  5. lc1 problems
    By woody69 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 07:39 AM
