Results 1 to 7 of 7
Thread: Adding logs together?
    Jan 2007
    Default Adding logs together?
    I searched but couldn't find anything?
    Today I ran a long log and 'ran out of frames?' half way.
    I pulled over, kept the truck running, extended the No. of frames allowed to 100 (x1000) instead of the 50 and started logging again.
    Is it possible to add those two logs together?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Sep 2005
    Not right now. Paul said we will be able to with the V8 version of the software when it get done, I believe.
    Jan 2007
    Thanks KB
    Howard
    DUCT TAPE.
    Aug 2005
    Quote Originally Posted by hquick
    Thanks KB
    If you're a programmer, the Flashscan API will allow for you to do this. I recall a few people discussing doing this quite a while back.
    Justin
    Jun 2005
    I know I made a quick spreadsheet in excel in the past for adding MAF logs or VE logs together. You just need to create some weighted averages to add them together.
    Example....
    Log 1 -
    BEN for 50kPa at 1200rpm: 1.01
    Cell count 504
    Log 2 -
    BEN for 50kPa at 1200rpm: 1.025
    Cell count 146
    Total cell counts for that data point: 650
    Equation: (1.01*(504/650))+(1.025*(146/650))=1.01337
    A little copy/paste of the equation to the right cells and that's it.
    Jan 2007
    Thanks....I might give it a try later. That's handy to know.
    Howard
    DUCT TAPE.
    Jun 2007
    Could be nice to join multiple logs when doing an autove tuning and you dont have the time to do on long log but rather several throughout a day or two.
    9.8@150 . LQ4 Turbonetics Billet 7575@18psi, 6 speed, non-intercooled with meth. Speed Density, open loop, no PE.
  1. Adding O2's
    By jsm00z28ss in forum Gen III V8 Specific
    Last Post: December 30th, 2009, 09:34 PM
  2. Adding headers + O2
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: July 28th, 2009, 10:12 AM
  3. COS#3 adding timing
    By minytrker in forum Custom Operating Systems
    Last Post: November 26th, 2008, 05:39 AM
  4. Adding fuel
    By Lennart in forum General (Diesel)
    Last Post: January 18th, 2006, 03:43 PM
