What model number of Dynojet wideband would work best for 97 Vette and EFILive?
voda1,
Welcome to the forum.
Just about any wideband will work because the EFILive software allows custom calculated pids.
The wideband has to output a preferably linear voltage ranging from 0V to 5V representing some AFR range typically which you can program into the wideband (e.g. AFR10 to AFR20).
