Results 1 to 3 of 3
Thread: Lean in OL
    Default Lean in OL
    I just tuned a camaro with a cam and bolt ons. I used COS#5 and it runs perfect in OL. As soon as I put in CLSD the car kept going real lean after the o2's cut on. While driving the car in OL the a/f was 14.6-14.7 when in CLSD it would go to 17-18 a/f. I kept going from CL to OL while driving with the scan tool and finally the o2's started working right it seemed and the a/f stayed around 14.7. I then went WOT and the a/f went up to 15 and I left out it. I tried on more time and same thing happened. I flashed it back to OL and went WOT and the a/f was 12.8 right where I had it when I did the tune. Any idea's Im lost. The o2 are brand new.
    Oct 2006
    This might be a stupid question but did you compare the O2 voltages when the wideband was connected to check that they were sane.
    Yeah, thats the weird part. When first going to CL the o2's were going crazy after awhile the calmed down. Once they calm down you can drive around easy and they will work fine fine. If you go WOT the o2 will go crazy again and make the car go really lean.
  1. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  2. lean low rpm??!!
    By nathans1987 in forum Custom Operating Systems
    Last Post: May 7th, 2009, 03:23 AM
  3. Going lean on top end AFR 19.5 WB !!!!
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: June 1st, 2007, 06:41 AM
  4. How lean can I go?
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2006, 07:47 PM
  5. Lean on tip in
    Last Post: April 8th, 2006, 01:51 PM
