Looking at main ve table - it says "Map kpa", and my scanner chart is in map kpa but they are not in synch, the ve table has rpm correct but map at 30?
2000 Camaro SS Convertible
M6,
LTs, AFR 205s, Comp xer 220/224, LS6 intake, Ported TB, AR TT IIs
Try going to the F8 tab and right clicking on the MAP pid to make sure metric is selected. I think that can cause some sync problems between the scanner and the tuning software.
That was it!!!! Once again - thanks!!!Originally Posted by SSpdDmon
M6,
