Results 1 to 3 of 3
Thread: high speed flash
    Jan 2006
    Default high speed flash
    I was tuning an 04 silverado 2500hd and it will not take high speed flash. This is the only time I have seen this. What causes it?
    Using v7.4?
    Anyway, one thing that seems to plague the Diesel world is these 'dumb' iPod adapters and XM radio adapters that tap into the serial data lines, if they have one of those fitted, pull the fuse, I know it wasn't a Diesel, but they they have anything like that fitted?
    FYI, we contacted a few of these companies and not one of them has any support built into the hardware to tell the unit to stop talking on the serial data bus when told to
    Jan 2006
    It does it with V1 and V2. The runs great, it just will not allow high speed flash. The thing that sucked the most was I installed COS#3 and forgot to the the updated one with the C and had to do it again. Spent an hour just flashing the pcm over and over. Its running COS#3 now so its all good.
  1. 6th getting locked out at high speed!
    By trailermasher in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 20th, 2022, 01:19 PM
  2. High speed onboard datalogging
    By limited cv8r in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 14th, 2012, 04:35 PM
  3. P10 high speed read/flash issue
    By ScarabEpic22 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: September 17th, 2009, 10:15 AM
  4. high speed scaning
    By redhardsupra in forum Gen IV V8 Specific
    Last Post: January 14th, 2008, 08:54 AM
  5. Use high speed
    Last Post: July 6th, 2006, 02:43 PM
