I have followed the righten and interactive to the best I can and when I paste and muptli with lables the b0101 goes flat at 500.00. On my loged bens I have some 600 and 500 from 1200 to 2800 RPM and at 20 t0 35 MAP.
Thanks Woody
Thanks Woody
Sorry I don't follow your question. Could you elaborate?
www.efialchemy.com
www.greatamericancarwar.com
Your BIN factors probably don't match (kPA versus PSI, Imperial versus Metric ) .Originally Posted by woody69
I think there is a 3D presentation of how to do VE in the Download section of Main or Home page of EFILive .
2006 Trailblazer
i had the same thing happen yesterday i forgot to change to average and pasted and multiplied the cell count
2002 ws6 stock short block
GMPP cnc LS6 Heads 11.4:1 cr
.576 i .581 e 116 lobe
D1SC @ 10#
723 rwhp 654 rwtq on E-85
when i clicked average it 0.00 everything out.
if it zeroed out then that means it didnt log any data make sure you have the correct pids selected if there is a line through any of the pids on your map screen then they have not been selected or as stated above make sure your pids match your MAPdouble check everything then do a new log the one you have is no good theres no dataOriginally Posted by tunedbyGM
D1SC @ 10#
OK thanks for the help. Now when I clicked the averaged button my averages were around .70 now do I have to go through the auto VE process a few times or am I doing something else wrong. How should I drive when I am loging for this, normal or hard . Thanks. Woody
Hard , normal , fast , slow , WOT second and third gear pulls , loading with the brakes (but be careful loading with the brakes , they can get hot) what ever it takes to hit as many cells as possible , the more the merrier .
You can't hit every cell in the VE table some are just way out of the rpm range and some are just above idle with some weird loads .
2006 Trailblazer
