Results 1 to 8 of 8
Thread: 100 wet shot
    Junior Member ytry's Avatar
    Apr 2006
    Default 100 wet shot
    Hey guys I just installed zex wet system on my 1999 ls1. I was wanting to know if I could get some help tunning I have read some other forums and some say I need to do timing only and others say fuel richen and timing.. I have a stock engine with all free mods pcm tune 3 inch exhaust and I have the nitrous installed in the air lid just before the MAF. If anyone has any info that would be great
    1999 Pontiac Trans-am: LS2 402, Free mods,Line lock, Nittos,Auburn 3.73's,EFI live tune, slp lid, All 3" exhaust with Magnaflow,
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    A wet shot is easily tuned by changing the fuel jet up or down as needed (log AFR with a Wide band) and shoot for 11-12 on spray. Use the scan tool to monitor for KR and adjust timing as needed.
    What you are describing though if your nozzle is in the air lid is a dry kit (only has one hose to it, being Nitrous, a wet nozzle has two hoses, one being nitrous and the other Fuel). Do not spray a wet nozzle through the MAF. A wet nozzle should be between the MAF and the Throttle Body.
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Apr 2006
    Ok I do have a fuel line and a nitrous line I went and took out timing and scanned it for KR. its running good! I do have the spray in front of the MAF>> what will it do to the MAF. I had read that on an lt1 to have it after the maf but on an ls1 it was ok to have it before because of the IAT.. Have I done a bad thing? The only place to put it after is on the rubber hose. How would I get a good seal there? any info would be great.. Thanks for the reply..
    Jul 2006
    Your MAF has a group of wires that measure the airflow. You are basically spraying gas on wires that are ment for airflow only.
    Wet nozzle kits are generally put in the air duct between the MAF and the Throttle Body. The nozzle should thread into a bung, the bung is installed in the air duct.
    Got a pic of your intake to TB?
    Maine USA
    Apr 2006
    I am out of town today but i will take one when i get back,, thanks for all the info.
    Lifetime Member Doc's Avatar
    Oct 2005
    Yikes!
    www.efialchemy.com
    www.greatamericancarwar.com
    Apr 2006
    ok im back in town and will take a pic tomorrow.. I hope I have not done anything..
    Jul 2006
    http://www.zex.com/Base/Instructions/ZEX143.pdf
    Instruction set for Zex LS1 kit
    page 7 says put the nozzle 6"-18" from the TB
    I would move the nozzle as I said, then clean the MAF with CRC MAF cleaner and start logging.
    If you have not noticed any drivability issues yet, your probably OK.
    Maine USA
  1. 75 shot Nitrous Dry
    By oztracktuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 21st, 2008, 11:43 PM
  2. How to tune for a dry shot??? N2O
    By WiseGuyZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2007, 04:28 AM
  3. Dry Shot 50hp
    Last Post: March 4th, 2007, 01:14 PM
  4. Tuning a 400 shot on a 408
    By minytrker in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 28th, 2006, 03:21 PM
  5. 50 Dry Shot Graph
    By Beer99C5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: October 22nd, 2006, 02:20 PM
