Results 1 to 4 of 4
Thread: system readiness test and O2 tests won't run in 7.22
    Jan 2005
    Default system readiness test and O2 tests won't run in 7.22
    I just upgraded to 7.22 and did a little logging. Now when it goes to run the O2 sensor testts it replies, "Could not be retrieved from the vehicle, Reason: PCM is not returning O2 sensor data, try SMS results" Any ideas why it would say this?
    Sorry for the "no reply" - I did not see this post until now.
    That message is displayed when the PCM does not return any O2 sensor data. In later years, GM moved the O2 sensor test results from their own dedicated area to the SMS test results.
    Try the SMS test results (the icon to the left of the O2 icon) and look for TEST ID $05 - which is the O2 sensor test results.
    Jun 2005
    I have a 2004 LS-6. I assume that this answer applies to me also?
    If you see Test ID $05 in the SMS results, then yes it also applies to you.
  1. Do not run the V2 self tests at this time
    By joecar in forum FlashScan V2
    Last Post: July 1st, 2010, 01:40 PM
  2. emissions testing coming up - system readiness test
    By 350SS in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2007, 01:48 AM
  3. 2Bar OS and Readiness Tests
    By trudynosports in forum Custom Operating Systems
    Last Post: August 1st, 2006, 09:18 AM
  4. Replies: 5
    Last Post: July 28th, 2005, 03:26 PM
