Having problems with a C5 automatic with a new Yank 3000 stall converter-The Trans keeps setting code P1870 and goes into limp mode and full trans pressure and shifts horribly hard and temps shoot up to 250*--I've done all the usual things but can't seem to get a handle on this one--I've read about the "TCC SLIP TABLE " and how an adjustment here can eliminate the p1870 & overheating--Can't seem to find this table--Can someone point me to it? It seems to be under a different heading--The table # would be great--Oh and also is setting the MAX # across the entire table to 100 and the MIN. # across the entire table to 90--- the way to go ???
