Results 1 to 10 of 12
Thread: PCM "Recovery"
    Lifetime Member jfpilla's Avatar
    Default PCM "Recovery"
    I've read in a number of posts in other forums that HP Tuner has a recovery feature.
    Is this so or is it a misunderstanding of how it works?
    LS1 Edit will fail for various reasons and a rewrite or pulling fuses will correct it.
    How will Flashscan compare to these two editors regarding "Recovery"?
    Can a PCM be fried with these editors for any reason?
    There are two ways to reflash the PCM:
    1. Reflash the entire flash memory including operating system and calibrations.
    2. Reflash only the calibrations.
    Option 1 has the potential to render a PCM inoperable and non-reflashable, that is what people call "fried". There is nothing physically wrong with the PCM, it's just that the "program" inside the PCM is either non-functional and/or no longer communicating with any off-board reflash tools.
    The only way to recover the PCM in this situation is to desolder the flash chip, program it using a chip programmer and resolder the flash chip to the PCM. Not something the average DIY tuner is prepared to do.
    Option 2 does not alter the PCM's operating system (program code), so no matter how many times this type of reflash fails, the PCM will still continue to communicate with the off-board reflash tool. That means, the off-board reflash tool can restart the flash (as many times as is necessary) until a successful reflash is completed. I guess one could call this recovery.
    So I guess Flashscan will reflash only the calibrations. That's very nice. Thanks Dirk and Paul.
    Sep 2003
    As a developer this is the dumbest shit i have ever heard of why do extra work that you dont have to (reading the whole 512) just read what you need to read and leave all that other shit alone ESPECIALLY volitle data. I also think this was planned only because every pcm that is killed because of an OS requires you to send carputing another 200.00 to add another license that is the only reason i can think of doint shit the long way. There is more things to mess up doing it this way. And as volitle as Windows is why would you even risk this? Corner the market maybe?
    Jul 2003
    ANother probability is because having the complete file will let you identify it easier and more compatible with other things...
    Quote Originally Posted by Dirk Diggler
    Dirk, LS1Edit 'reads' the entire 512K as there is some important info in there that is not in the calibrations area.
    However, they do only reflash the calibrations area, leaving the Operating System alone, they 'should' be able to restore a PCM as the PCM is still able to communicate (slightly more limited) when just the calibrations have been wiped.
    Oct 2003
    So does this mean its just a matter of knowing how to properly communicate with a confused PCM?
    2003 Silverado SS
    N/A: 14.257 @ 94.63 mph
    N2O: 13.200 @ 102.3 mph
    Quote Originally Posted by deezel
    Well, yeah.
    The only way you can kill them to the point of needing to pull the chip off is if some important comms routines at the very start of the Flash get wiped, that will only happen if you are programming the cals 'and' the Operating System, like what GM would do, and yes, Tech2 does kill them every now and then.
    Sep 2003
    All the dealers i took them to said they couldnt flash it because the PCM refused to communicate with the Tech2
  1. EFI Connection "24x" System and LS1 PCM for Early Small-Block Chevy
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: June 1st, 2009, 03:53 PM
  2. what table controls start up decay speed? "how fast it decays out"
    By mvvette97 in forum Gen III V8 Specific
    Last Post: March 20th, 2009, 12:10 AM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
