Results 1 to 10 of 17
Thread: 1024k RR
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default 1024k RR
    Has anybody in Australia ordered or is using a 1024k RR. Do they suit the VY commodores with ETC. Do they look like attached pic.
    No the 512 unit is what you need for a VT-VY , and the 1024 if only for the VZ LS1 , I have 4 of each for tunign and they look exactly like the std LS1 PCM.
    that pic is of a E series PCM
    May 2005
    my mistake, I meant VZ. So the 1024k RR is the one I need for VZ's
    Lifetime Member MICK's Avatar
    Mar 2005
    Default vz
    Quote Originally Posted by limited cv8r
    yeap!
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Quote Originally Posted by Delco
    4 of each????????
    Did I read that correctly?
    ie 4 x 512 RR'S
    4 x 1024 RR's
    Dave.
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Will that 1024K RR (Or a similar one) work with the LLY Duramax?
    Quote Originally Posted by Cougar281
    Dont think so, but I thought I heard Craig Moates made a LB7 D-Max one, maybe he's doing LLYs now too?
    Jan 2006
    Quote Originally Posted by ScarabEpic22
    Yes, there is a LB7 RR... that 1024K RR kinda gives hope for the LLY as the LLY ECM *LOOKS* the same (I know the LS2-style PCM has different guts, while the exterior looks the same) and is 1024k in size. IIRC, one of the challenges mentioned with regards to a LLY RR was the case design and where to put the RR components.
    Ahh, that makes sense. Thanks for educating me. Good to know little tibits of info like this, never know when its going to be important.
    Quote Originally Posted by Biggsy
    4 of each????????
    ie 4 x 512 RR'S
    4 x 1024 RR's
    yep do lots of cars with cams/blowers etc that take days to tune properly
  1. 512k or 1024k Road Runner???
    By hquick in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 23rd, 2008, 04:31 PM
