Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 1024k RR
  1. #11
    Lifetime Member Cougar281's Avatar
    Jan 2006
    I just re-read the second post. The 1024k RR doesn't look like the LS2/LLY ECM, it looks like the LS1/LB7 ECM, so maybe we're not that close to having an LS2 or LLY RR.
  2. #12
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Quote Originally Posted by Delco
    yep do lots of cars with cams/blowers etc that take days to tune properly
    Cool, got a full on production line going on!
    8 RR's , all I want is one!
    Dave.
  3. #13
    Jun 2007
    Hey guys
    I am trying to get the RTACS going on a Holden CV8Z with the 1024k PCM but it won't auto adjust the VE table.
    As you know it uses the ETC fly by wire.
    It works fine when i use the 512k PCM on pre VZ cars.
    I have been searching for this info but have found no one else with the same problem.
    would i have to play around with the accuracy settings ?
    Any ideas ?
    thanks in advance for any help.
  4. #14
    Quote Originally Posted by Stelth
    Hey guys
    Any ideas ?
    All my 1024 RR's work perfectly with autotune , I would suggest it is a setting you have wrong.
  5. #15
    Jun 2007
    That's what i'm thinking.
    I have emailed Craig but he has not responded yet.
    I will keep trying .
    thanks Delco
  6. #16
    Feb 2006
    There are firmware updates for the RR to work better with RTACS. Mine did not want to cooperate until I updated it.
    Al
  7. #17
    Jun 2007
    Quote Originally Posted by ChipsByAl
    Al
    That came to my mind aswell so that's the first thing i checked .
    But It already had the latest update.
    cheers
  1. 512k or 1024k Road Runner???
    By hquick in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 23rd, 2008, 04:31 PM
