All
I have completed a procharger install and am ready to do the wide band O2 AFR tune usinf V2
I believe that I have hooked up the Innovative LC-1 correctly. Did the "open air" calibration and then did the LC-1 programming for AFR use with EFILive.
Set all the recommended PIDs, per the tutorial, took car for a ride the EFILive Wide band AFR reading are about 1/2 of what they should be i.e. Min 7.36 AVG 8.54 Max 9.77
I know that these cannot be real AFR readings.... There must be something obviuos to you that I left out.
Calibration wrong, PID left out needed for calc, something?
Comments please.
Bob
PS : The ELILive tutorial is for V1 is there anything different for V2
