Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: Evaporative purge system not ready
  1. #41
    Member way2much_01's Avatar
    Sep 2007
    I have a cos5 tune would that have anything to do with it?
    BlackBear, HSW N20 100 shot
  2. #42
    Quote Originally Posted by way2much_01 View Post
    Your COS5 tune is based on 12212156...
    it should still run all the monitors (unless you disabled DTC's).
    You could try full flashing back to your base OS 12212156 and see what happens.
  3. #43
    Sep 2007
    Is there anywhere I can get a stock tune to compare them because I didn't tune it someone else did
  4. #44
    Can you get your stock tune from your tuner...?
    You can try looking in www.tunefiledepot.com
  5. #45
    I would go back to the stock tune (12212156)... you should be able to find it at www.tunefiledepot.com
  6. #46
    Sep 2007
    I looked up your vehicle 2002 Sierra/Silverado 4.8/5.3/6.0...
    so I don't really know why your PCM reports EGR as not supported (COS5 should report it the same as 12212156).
    C0265 is an ABS code, so it does not effect the smog test.
    Sorry about the post it's fixed, the truck is the same from when I got it and it had to pass smog before we transferred so the only thing I can think of is the custom tune
  7. #47
    No worries... if the truck is physically unmodified, then you should be able to pass on the stock tune.
  8. #48
    Your stock tune might not be 12212156... just look for the one of the 2002 Silvarado/Sierra tunes that matches your engine size.
  9. #49
    Sep 2007
    You know where I might can find 1?
  10. #50
    Goto www.tunefiledepot.com, look under stock tunes, look under Chevrolet and GMC...
    I didn't see one for 2002 Sierra, but try the 2002 Silvarado (of the same engine size).
  1. This may suck... or the Evap Purge and OL
    By Wolfie in forum Gen III V8 Specific
    Last Post: July 24th, 2008, 01:35 PM
  2. 98-99 pcm swap ? 69 brown evap purge
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2008, 04:51 AM
  3. LTFT under high manifold vacuum & EVAP Purge
    By vettenuts in forum General (Petrol, Gas, Ethanol)
    Last Post: July 25th, 2006, 10:10 PM
