Do I need PID GM.AFR? for wide band in an LS2 (LC-1) I get RED X
For an LS2 I believe I would need GM.AFR_B
If this is the case then the LC-1 calculation would be incorrect....
Thanks - Bob
Thanks - Bob
If it is similar to the P10 PCM, then you would need to use GM.AFR_B and change the SAE generic text file calculation for the LC-1. The value that GM.AFR gives in the P10 PCM makes no sense.
For the LS2 GM.AFR isn't an available PID. I substited GM.AFR_B in the file.
Still having other problems.
Thnks for the response.
Bob
