Results 1 to 4 of 4
Thread: EFI says RR PCM is Locked
    Lifetime Member Chalky's Avatar
    Sep 2003
    Default EFI says RR PCM is Locked
    I keep going just to see what else can go wrong. Latest:
    Never got BT to work but have a connection with USB. I downloaded os and tune from old pcm. Installed RR and tried to upload file to RR PCM and get the following erros:
    Bootloader rejected
    EFI could not unlock PCM.
    Any ideas.
    ANy idea why PCM would be locked as received? I tried writing an update to it yesterday but forgot PCM did not have an OS at time.
    2015 Z06 A8
    Don't use the "normal" read/reflash options to read/reflash a RR PCM. THey don't work because RR has no flash memory.
    You must only use the RR read/reflash options on the RR control panel.
    Quote Originally Posted by Chalky
    The PCM is "locked" only because the locking codes are stored in the flash memory which does not exist. The EFILive<->RR link has full control of the entire RR RAM that is emulating the flash memory so it is sort of irrelevant that the PCM thinks itself is locked.
    Sep 2003
    Default Thanks Blacky and Craig
    Just got off the phone with Craig and I see your reply. Just wanted to say thanks for the reply and the informative conversation with Craig Moates .
    I believe we have everything back under control.
    2015 Z06 A8
  1. I Locked PCM but now have new V2
    Last Post: September 16th, 2008, 01:13 PM
  2. locked ECM
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: June 4th, 2008, 05:30 PM
  3. E40 ECM locked
    By LBZ_YFZ in forum Gen IV V8 Specific
    Last Post: April 4th, 2008, 01:37 PM
  4. Locked PCM?
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2006, 01:46 PM
  5. 98's (Locked)
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2005, 09:54 AM
