Ok, so far since I have been fooling with my v2 I have only changed My timing in high and low octane tables 1 deg up across the board but have not flashed it to the ecm yet.
I was thinking I can go more from a stock tune , what do you all think?
If I add 4 degrees total across the board would it be ok if I run 87 or go up to 93 oct.
I also eliminated the delay in PE. I am going camping tomorrow morning and would like to flash the new tune to the truck before I go, is this a decent start? what are some other things to do that will help but not be drastic?
THanks to all for the info I already have from the forums.
