Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
Thread: PLX, V2 Voltage Offset - HELP!
  1. #21
    Link appears to be working...
  2. #22
    Lifetime Member Chalky's Avatar
    Sep 2003
    Smile
    Does now!
    2015 Z06 A8
  3. #23
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Default What date was this?
    We have made a firmware fix for jittery A/D inputs. The FlashScan firmware now 10x oversamples the A/D inputs and averages the input data every 100ms. That conditions the incoming data and provides a more stable A/D value to the EFILive software.
    I've attached the firmware with that update here. Unzip the file into \Program Files\EFILive\V7, then run the firmware programmer to update FlashScan's firmware with the new V64 file.
    Hey Paul... I'm suffering with this.... Ross just e-mailed me and wants to know why I'm e-mailing with him and what I'm going up at 3:30am us tiime....
    ANSWER: I'm dying! Please get us serial AFR into V2 soon!
    Is this firmware current or do I already have it from another update?
    Chuck
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
  4. #24
    Feb 2007
    Does post #2 of this thread help: showthread.php?t=4593
    I've checked the offsets on both my wide bands, both read around 0.03 volts lower than the programmed 1V and 4V output from the LC-1's in EfiLive.
    Would the process you describe remove the 0.03V negative offset?
  5. #25
    Quote Originally Posted by Gelf VXR
    IIRC, it should get it to within 0.02V which compared to 5.00V full scale is 0.4% error.
  6. #26
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    If it is consistently -0.03 off, would adding 0.03 to the calculation in sae_generic.txt make it read correctly?
    Right now it is:
    # PLX WBO2
    *CLC-00-920
    V 0.0 5.0 .1 "{EXT.AD1}"
    AFR 10.0 20.0 .1 "{EXT.AD1}*2+10"
    Why not make it:
    # PLX WBO2
    *CLC-00-920
    AFR 10.0 20.0 .1 "({EXT.AD1}+0.03)*2+10"
  7. #27
    Aug 2005
    A better bet would be to add .03 to a calculated PID in calc_pids.txt. This file will not be overwritten with future software updates whereas sae_generic.txt will.
  8. #28
    Sep 2003
    Sounds like a better idea.
  9. #29
    I like that idea also.
  10. #30
    Feb 2007
    Great, I'll make the changes in the calculated PID, thanks
  1. CMP retard offset signal?
    By Aloicious in forum Vortec V6/V8 Specific
    Last Post: July 2nd, 2009, 03:26 PM
  2. Wideband AFR rpm offset?
    By Highlander in forum General
    Last Post: June 15th, 2008, 01:34 PM
  3. b0304?? baro offset...
    By ls698ta in forum Gen III V8 Specific
    Last Post: March 20th, 2008, 08:12 PM
  4. Measuring Voltage offset
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: September 9th, 2007, 06:03 AM
