Results 1 to 3 of 3
Thread: Highlighted Cells?
    Jul 2005
    Default Highlighted Cells?
    How come we see different results when we highligt a section of the scan? I show more knock when I just look at a section.
ID:	1698   Click image for larger version.
Name:	knock 1section.jpg
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Oct 2006
    The lower resolution map shows an average of all the hits in that cell. If you expand on the map there are less hits to average out per cell so the value will change.
    The map is showing events from only inside the highlighted area of the chart, so the map cells will be different.
  1. How to select mutliple cells in a row to smooth?? but not all of the cells.
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2010, 03:34 PM
  2. Reset Tap Cells
    By jaydog in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 23rd, 2009, 08:05 PM
  3. MAP cells all the same colour????
    Last Post: October 21st, 2008, 05:02 PM
  4. PLX WB reading 13.6-13.62 in all cells
    Last Post: May 19th, 2006, 04:16 PM
  5. How do we hide cells ?
    By johnv in forum General
    Last Post: September 8th, 2005, 02:20 PM
