Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: What am I supposed to do now?
    May 2007
    Default Still trying to connect.
    I installed a cam last week, which took less time than I have put into EFIlive so far, without even getting connected. Here is what it says in my "Console".
    18:28:44.312: Scanning for EFILive FlashScan V1 USB
    18:28:44.328: Autodetect interface ...
    18:28:44.343: Current protocol set to: "SAE J1850 VPW"
    18:28:44.765: Interface firmware version: 1.2.17
    18:28:44.765: Connection to [FSP] interface is OK
    18:28:44.765: Autodetect PCM...
    18:28:45.296: PCM not detected.
    18:28:45.296: Autodetect ECM...
    18:28:45.812: ECM not detected.
    18:28:45.812: Autodetect TCM...
    18:28:46.343: TCM not detected.
    18:28:46.375: Interface firmware model: FSP
    18:28:46.390: Interface firmware version: 1.2.17
    18:28:46.406: Interface firmware date: Jan 18, 2005
    18:28:46.421: FlashScan serial number: 003601369227
    18:28:46.781: Initialising PIDs...
    18:28:46.968: Initialising Modules...
    18:28:46.968: Ready.
    If I disconnect my usb cable, it knows that and gives a different error. If I disconnect behind the v1, I get the same message as above. My cig outlet is working, and if I pull the fuse, same message as above. So, I connect and old program called "Pro Scan". It works fine, finds and deletes codes, reads TPS, coolant temp. So if anybody out there can help me before I go insane and scrap this whole plan I would be forever grateful. If not someone will get one hell of a deal on this.
    Aug 2004
    Are you selecting the correct pcm type? It sees the cable just fine, the computer just isnt talking.
    May 2007
    Yes 97/98 GEN III, its a 98 Z28.
    Lifetime Member Doc's Avatar
    Oct 2005
    Hello,
    The scan tool is not connected/turned on?
    www.efialchemy.com
    www.greatamericancarwar.com
    May 2007
    The cables are connected but from what I can tell it dont see the pcm. It acts the same whether the key is on or off, or even if the cable is unplugged from the car or the V1. But I know there is nothing wrong with the OBD port because my PRO-SCAN connects fine.
    May 2007
    Default What am I supposed to do now?
    I have been trying for a week, made 2 threads on here and ls1tech, and have not gotten an answer to why V1 won't detect my pcm. What the hell do I do?
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    What error are you getting? I had the same problem once and my ODB fuse (which is the same as the cig lighter) was bad.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    98RZ,
    Do you have access to another F-body car...?
    If you do, see if it connects on that car.
    If your Pro Scan tool works, I'm wondering if there's a problem with your FlashScan V1...
    do any of the LEDs on it light up when you connect to the PCM without the USB...?
    Where are you located...?
    Joe
    After you have attempted to connect to the vehicle, please select the menu option: File->Generate Error Report and save that report and email it to me at paul@efilive.com.
    May 2007
    Joe, yes the lights did flash when connected without the usb. I am trying to find someone local in MN to help.
    Paul, email sent.
    thanks, Greg
