Results 1 to 3 of 3
Thread: Twin Spark Maps?
    May 2005
    Default Twin Spark Maps?
    I don't fully understand why twin spark maps are important/a benefit when in SD. Can anyone shed some light? How are these set up properly?
    1999 RCSB: P1SC, 57lb inj, E-fans/34\" rad, 3:73-Eaton 18\" Toyo\'s, Flashscan-FJO, Griffin IC, FLP level 5 and PI 10.5\" 3-disk....
    Sep 2003
    Without the custom os when you unplug the maf the PCM uses the Low octane table for spark. Most of us SD guys running 1 bar have copied the hihg octane table to the low cotane table. This takes away our protection from Knock and bad gass. The twin spark maps allow you to maintain high and low octane functionality in the absence of the MAF sensor
    May 2005
    That makes sense, when I used to tune with edit, I always just copied the high to the low and called it good. I guess it is probably smart to use both tables now!
  1. Dual Spark Maps - Difference ?
    By Happy Jim in forum Custom Operating Systems
    Last Post: December 30th, 2006, 11:08 AM
  2. Applying KR logs to Spark Maps
    By CTP Racing in forum General (Petrol, Gas, Ethanol)
    Last Post: September 29th, 2006, 04:00 AM
  3. Dual spark maps, let me get this straight????
    By nitrorocket in forum Custom Operating Systems
    Last Post: August 9th, 2006, 10:16 AM
  4. Dual spark maps SD mode
    By APE346 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2005, 12:11 AM
  5. V5 spark and fuel maps into V6?
    By emarkay in forum EFILive V6
    Last Post: May 24th, 2004, 07:58 AM
