Results 1 to 5 of 5
Thread: 411 PCM's
    Default 411 PCM's
    If we could get 78 people... ...we could each buy a 411 PCM for US$50...
    http://www.allworldautomotive.com/au..._ots10049.html
    Jan 2007
    You can get them in LA for $100ea Joe! (as one off's).
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Howard, I can't seem to locate any... sent you a pm.
    Jan 2007
    http://www.pacificp.com/forum/viewtopic.php?t=3666
    This is the thread where we did a group buy originally (Eric arranged it). AAA Auto parts.
    Howard
    DUCT TAPE.
    Aug 2004
    I sell them for 75 a piece not programmed.
