Results 1 to 3 of 3
Thread: 12200411 retrofit, have efilive "VIN" question
    Oct 2006
    Default 12200411 retrofit, have efilive "VIN" question
    I am tuning a car (57 pontiac with a 1998 5.7 vortec) that has a 12200411 PCM installed (it was out of a 2001 G van, express van, etc.). Car runs OK, but needs some tuning. I bought EFI live Personal Scan&tune and installed the software (V 7.3).
    When I start up the software, it asks me for the VIN number.... well I don't know what the vin would be for this one. I am assuming it needs the VIN so that it can load the proper calibration files for the data stream?? So could I just use any VIN number that would be right for a 2001 G van? If so, any idea where I could get a VIN? I also noticed that the 12200411 PCM was not on the drop down menu, can someone help a newbie out?
    thanks,
    rb
    Jul 2005
    I take it that you are trying to scan. Open your Tuning tool and download the PCM files to your computer, that should give you the numbers you need and the baseline tune you want to work from.
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Pretty sure you select the LS1 ECM type for that ECM, and download the tune first to get the VIN #.
  1. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  2. Replies: 5
    Last Post: August 14th, 2007, 10:57 AM
  3. Is the tow/haul button considered "performance" in efilive?
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2007, 10:12 AM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
