Results 1 to 6 of 6
Thread: kpa #`s at WOT
    Nov 2006
    Default kpa #`s at WOT
    what should KPA #`S be at WOT for a N/A 383 ls1?
    i can sometimes hit 90 kpa but rarely.
    wot for me is 85 KPA.
    i am wondering if it should be higher.
    i`m using the ls6 intake and stock throttle body and slp lid.
    do these #`s seem low?
    Sep 2005
    What is you altiutude, and your key on, engine off kPa numbers?
    Jul 2005
    Should be able to reach same KPA as key on engine off.
    http://forum.efilive.com/showthread.php?t=5396
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Nov 2006
    i`m mile high, and key on is 83 KPA.
    i ask because i have seen people with N/A motors hitting higher #`s
    and was wondering if i had a leak.
    Sep 2005
    Quote Originally Posted by mr.prick
    You really can't get higher that your key on kpa unless you have some sort of forced induction. Sound like your setup is flowing quite well if your key on is 83 and you have seen 85.
    Nov 2006
    cool
    thanks
