Results 1 to 7 of 7
Thread: LD9/LN2 .tun file
    Default LD9/LN2 .tun file
    Is there any chance someone could throw one of these files my way? Now that EFILive supports these engines, I'd like to see exactly what settings they support. Thanks.
    Aug 2004
    If you send me a cal file via email, i will send you the files needed.
    I don't have a cal file or anything for that matter. I currently own HPTuners and want to compare EFILive to their offering.
    The only thing I've found that's relevant to anything is the flash dump located in this thread:
    http://forum.efilive.com/showthread.php?t=4832
    Regardless, thanks for your quick response.
    Aug 2004
    I have not seen any other companies support, so i cant compare either, but EFILive should have everything you need and alot more. Also the Roadrunner on the fly tuning should work with the pcms also.
    Regardless, I'm still in need of seeing exactly what EFILive offers for these specific engines. I'm not about to shell out a decent amount of money for a product without knowing exactly what it can do for the applications I intend to use it with.
    Again, thanks for the quick reply.
    Aug 2004
    there are 190-250 perameters available, from engine to transmission. If you can think of it, it is in there.
    Again, I'd appreciate having the proper files to see the parameters for myself within the demo version of EFILive.
  1. P12 PCM file
    By Chevy366 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 29th, 2009, 08:28 AM
  2. cax file?
    By myws6formula in forum CAX Files
    Last Post: December 21st, 2008, 03:00 PM
  3. Would someone be willing to look at a log file?
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: May 6th, 2007, 08:47 AM
