I have a 97 C5 auto I have the dreaded blinking a/c light.Freon is good,Pressure is good.When I hook up the scan tool and go to bidirectional then control panel and click on a/c on the control panel my a/c works fine,No blinking light,The light stays on on the a/c button,Ice cold a/c,No problems.My question is,Does it bypass the PCM,What wires in the OBD port does it use to turn on the a/c.Does it ground it out or send voltage.Would anybody have a wiring diagram from the OBD port to the HVAC system.I'm just trying to narrow it down.....Thanks..........Paul
