Results 1 to 3 of 3
Thread: Have to flash twice?
    Apr 2007
    Default Have to flash twice?
    I did the 98 to 99+ swap!
    The car runs fine, then I flash it, it starts up, runs ok for 15 seconds, then starts running horrible! I let it run (once for 15 min) but mostly it idles, but if I touch the gas it dies. I re-flash with the same flash, at 15 seconds it starts to stumble, then clears up, and runs fine after? Any ideas?
    Apr 2007
    I Figured this out, but did not have time to post. The MAP was plugged in the wrong spot. For some reason the first time I flashed the AFR went nuts, the seconfd time it must have gone into limp mode and disregarded.
    Sep 2003
    Good to hear you got it worked out.
    I'm old and Retired! I used to go fast. I don't go so fast anymore ...but, my cars still do!
  1. did i flash or not
    By Eric in forum Gen III V8 Specific
    Last Post: March 30th, 2010, 06:18 AM
  2. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 12:43 PM
  3. OS Flash
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2009, 02:15 PM
  4. No Flash!
    By horsehaulin in forum Duramax LB7
    Last Post: May 31st, 2008, 04:22 PM
  5. Can i flash my VIN in a used PCM?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: September 18th, 2007, 12:23 AM
