Quote Originally Posted by MICK
1: ECM ram request (dump memcal).
Here's the problem with that, depending on the time the request was received depends on which bank of ROM dump you get, for dumping out 128K it is useless as you get a mix and match of both banks. From memory it is limited to a 2 byte address, it needs to be 3 (or something like that)
I see in the later definitions for the VS and VT, that use the 010 chips are lacking the same sort of support in the definitions.
I think we moved on to LS1 by then
My last and finial question: Not putting any acid on anybody, Paul mentioned that V4 possibly would be incorporated into the all new V8 software, I was just interested in the time line on this to ascertain weather or not it would be worth pursuing these options?
We were hoping V8 would be in beta by now , obviously that is not the case so I am not even going to guesstimate a time frame. But yes, V8 will have full ALDL functionality.
