Results 1 to 6 of 6
Thread: switched modes??
    Apr 2007
    Default switched modes??
    In the tuning table D0409 it talks about using two switches, One for performance mode and one for manual mode. Switching to manual mode, will that actually make it act as a manual valve body??
    thanks
    Senior Member Wasted Income's Avatar
    Dec 2005
    <----------- Also wondering!!!! Anybody???
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Some PCM's treat manual 2nd as "hold 2nd" while others treat it as "automatic 2nd" (i.e. automatic PT upshifts/downshifts between 1st and 2nd)...
    the manual switch allows the behaviour of manual 2nd to be selected as "hold 2nd" (i.e. manual mode) or as "automatic 2nd (i.e. automatic mode)...
    I don't rememeber which vehicle had the manual mode switch... I think it was a 1994/1996 Firebird V6...? I haven't seen one since, altho some trucks may have it.
    In all cases, manual 3rd is always "automatic 3rd" (automatic PT upshifts/downshifts between 1st, 2nd, 3rd)...
    In all cases, depending on the WOT tables, 1->2, 2->3, 1->3 (D0913, D0918, D0919) upshifts may still occur.
    So it's not quite a manual valvebody.
    Apr 2007
    Default thanks for that
    thanks for clearing up the question about manual mode.
    as for useing these modes, I have the wires run in cab, just havnt had time to fool around with it yet. let you know when i get to it.
    Lifetime Member blindawg's Avatar
    Sep 2010
    Is this still true? I'm wondering if it is now used for push button shifting?
    Thanks,
    Branden
    Push button (paddle) shifting is implemented by manipulating the shift solenoid signals;
    the 4L60/65/70E/4L80/85E require the manual valve be in a specific position for this to be allowed;
    the 6L80/90 are fully electronic and allow all ranges/gears to be electronically selected.
  1. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  2. switched to mini-usb cable....eureka!!
    By Cablebandit in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 21st, 2009, 09:16 AM
  3. Knock modes
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: October 26th, 2006, 06:08 AM
  4. Switched tranny table=lost total spark?
    By slowhawk in forum General (Petrol, Gas, Ethanol)
    Last Post: May 26th, 2006, 12:08 PM
  5. What do the different TCC modes mean?
    By thunder550 in forum General
    Last Post: May 6th, 2006, 10:36 AM
