Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Idle Issues
  1. #11
    Jun 2005
    Quote Originally Posted by RacerChris
    I have not done the RAFIG or RAFPN process' yet, I am running the stock converter but I am upgrading in about a month to a 3000 stall converter, and I am idleing at 675 up from 550. I adjusted it to try to fix the problem but it didnt help much. Should I switch back to 550?
    One last thing.... How to I take a screenshot of my tiing tables so that I can post a pic of it in the forum for you to see and also how do I go about posting the pic?
    Thanks again!
    If you're not idling below a MAP of 60kPa, your idle is set too low. You may have to try 750~800rpm. The bitch is going to be that stock converter slamming the drivetrain when you put it in gear. That's the main reason why I don't suggest running a cam on the stock converter. You might be able to soften that up in the Trans folders though.
    To take a screen shot, you hit Print Screen, open up MSPaint, and then Ctrl+V to paste the image. You may have to resize or use only a portion of the picture and save it as a jpeg in order to meet the maximum size requirements of the forum. You can include it in your post when you do an advanced reply under Manage Attachments.
  2. #12
    Apr 2005
    Well I changed my base timing for in gear and neutral while at idle and that seemed to have helped alot but I still die when going from neutral to drive and now I am getting spark retard due to knock. I think I am going to wait on trying to cure this problem untill my converter comes in and then I will do the RAFIG, and RAFPN processes as well as readjust my base timing.
    Thanks a ton though guys for pointing me in the right direction!
  3. #13
    Apr 2005
    Well I couldnt wait to start playing with the RAFIG & RAFPN processes so instead of waiting another 3-4 days for my converter I went ahead and tested it out. All I can say is WOW!!!!! What a difference in my idle issues!!! I have only gone through the process through warm-up in gear once and then a few more times in gear while it was hot but it has made a huge difference!!! No more stalling going into drive, even with the stock converter and my cam! I have even been able to drop my idle a bit more due to the difference.
    I have a question though..... Does anyone have any advise on how to get the engine cooler quicker but in a safe way?
    Thanks again guys for the help!
  4. #14
    Jun 2005
    Drive up on rhino ramps, raise hood and run some fans. You don't want to hose it down if that's what you're asking.
  5. #15
    Apr 2005
    Quote Originally Posted by SSpdDmon
    Well I wasnt going to go that far but I do admit if I were a few years younger it might have crossed my mind!
    The answer you gave was pretty much what I was looking for, I figured using a fan but I didnt think about putting it on ramps as well.
    Thanks again!
  1. idle issues...
    Last Post: May 8th, 2010, 10:11 AM
  2. 98 cam only minor idle issues (log inside) HELP
    By bad6as in forum Gen III V8 Specific
    Last Post: April 9th, 2009, 10:56 AM
  3. In gear Idle issues....
    By LPDTuning in forum Duramax LB7
    Last Post: March 23rd, 2008, 12:34 PM
  4. Surging idle issues - please help!
    By tunedportcj5 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 22nd, 2006, 01:41 PM
  5. a couple idle issues here.
    By BACKinBLACK in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2006, 01:17 AM
