Results 1 to 6 of 6
Thread: A/C Fan power table pressures too high?
    Sep 2003
    Default A/C Fan power table pressures too high?
    Looking at the Fan Power ACP, it seems to be set to run the A/C at very high head pressures. R134a refrigerant typically runs at around the 700 to 900 kpa range in normal air conditioning applications however the standard PCM settings look to run this pressure much higher, probably around the 1500 kpa mark.
    Running at this pressure means more engine power is required to run the compressor and also impacts on A/C cooling efficiency.
    Are there other reasons why these setting are so high? The only thing I can think of is that bringing the fans on earlier for the the sake of A/C effiency might cause the engine to run too cool. Any thoughts on this one?
    VZ LS2 HSV R8 . 1.8 ratio rockers, 918 valve springs, pod filter, DF headers, High flow cats, twin 3", Basic tune (work in progress), 289 rwkWs (dyno Dynamics)
    Sep 2003
    Quote Originally Posted by JohnW
    Hmm, Interesting...
    The thermostat should keep the engine temp within bounds even if the fans were on full time.
    Maybe the actual head pressure should be verified and compared to the PCM settings?
    I'm old and Retired! I used to go fast. I don't go so fast anymore ...but, my cars still do!
    Oct 2006
    Doesn't the PCM have to reach two sets or values to run fans , 1. coolant temperature 2. AC pressure ?
    And isn't there a fail safe for the AC ?
    The max on mine is {G0918} 255.08 PSI .
    2006 Trailblazer
    Sep 2003
    Quote Originally Posted by tunedbyGM
    As far as the pcm having to reach two sets of values to run the fans, it may be that if either of the two values are met the fans will turn on.
    Oct 2006
    Quote Originally Posted by Maggie
    That is what I was trying to say , either or has to be met , temp or pressure one or the other .
    Most times A/C pressure is met first because at cold starts the temp is not sufficient enough , and A/C pressure will trigger the fans for a short period , after temp is reached I think temp triggers the fans more often than A/C pressure .
    2006 Trailblazer
    JohnW, welcome to the forum...
  1. trans pressures
    By drdarthinvader in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 25th, 2009, 08:18 PM
  2. Spark High Octane table
    By SHOGOR in forum Gen III V8 Specific
    Last Post: July 19th, 2008, 02:53 AM
  3. shift pressures
    By bifster in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 31st, 2006, 07:55 PM
  4. High RPM power loss solved
    By PSWired in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 16th, 2005, 12:43 PM
  5. Replies: 2
    Last Post: August 7th, 2005, 03:04 PM
