Results 1 to 10 of 10
Thread: June V2 update
    Lifetime Member jfpilla's Avatar
    Default June V2 update
    It seems that the speedometer calculator isn't working right for C5's when you change gears. The shift point adjuster, automatic and selected %, always selects 0% correction.
    If you change tire size the shift point selector does make a change.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Paul,
    It seems the shift point calculator still isn't working.
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Hi Joe,
    Sorry if this is an obvious queastion, but are you using the latest software version?
    http://www.efilive.com/download.aspx#download1
    Hi Joe,
    Paul,
    Yes, as well the latest update.
    EFILiveV742_534_666_657_60
    EFILiveV742_535_667_659_61
    Does your reply mean it's only happening to me?
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    I am talking about the shift point correction tool.
    Would someone like to try it and see if it's me or the tool?
    joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Joe,
    So you're saying that if you change the gear ratio the correction says 0%...
    but if you change tire size then it says the right correction...?
    Quote Originally Posted by jfpilla
    Paul,
    Joe
    No, not at all. There are many of "issues" related to calculating the correct speedo settings and shift point adjustments. It is something that we will be addressing in the very near future. I just wanted to know which version you are using so that I'm not chasing ghosts that may have already been fixed.
    When I get a spare minute, I will try to write up a "this is how the PCM calculates the various speeds" tutorial which will allow customers to figure out most settings for themselves. If you know how it works and why some values appear to be wrong and what are the limitations of the speedo calculator, then it makes it a lot easier (and probably more accurate) to configure the various settings manually with a pen/paper/calculator.
    Joe,
    If I change the gear ratio and select apply it makes the correct changes to the "Speedo Calculator". It then sends you to the "Shift Point Correction'' table, but applies 0 as the correction factor. If I change tire size it will apply a correction factor. I don't know if it's correct or not.
    Try it for yourself. Only change the gear ratio and apply it. What correction factor do you get?
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Paul,
    V1 did calculate shift points pretty well. Here's a screen shot of what I get.
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Paul,
    I did enter a 3:15 gear ratio to my current file(3:90s) and the Speedo Calculator numbers do compare well to my stock 3:15 file. It just no longer creates new shift points. Hope this helps.
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  1. BBL installer update: June 22, 2008
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: July 3rd, 2009, 05:28 PM
  2. BBL installer update: June 12, 2008
    Last Post: June 22nd, 2008, 07:57 AM
  3. BBL installer update: June 12, 2008
    By Chevy366 in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 10:37 AM
  4. Minor typo in the June 13th update
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: June 14th, 2007, 05:27 PM
