Results 1 to 5 of 5
Thread: idle after restart
    Aug 2006
    Default idle after restart
    I'm struggling with how to approach this problem. The car seems to start and idle fine 650-750 RPM when it's cold. If you shut it down and fire it right back up it starts wierd. Initially around 500 RPM drops momentarily to high 300 RPM range, then settles out to 700. This is all in the matter of 10 seconds or less.
    I tried to follow the following post regarding the RAFIG process ... but it just didn't seem to work for me. I did not understand what I was looking at.
    http://forum.efilive.com/showthread....ighlight=rafig
    I have attached a log of what I think shows the problem. It should be a bunch of starting stopping of the motor (I'm not at my tuning PC so I can't verify), let me know if the log doesn't make sense ... I can post a new one later.
    Jun 2005
    Startup Friction Airflow Correction
    http://forum.efilive.com/showthread.php?t=4661
    Aug 2006
    Quote Originally Posted by SSpdDmon
    Thanks ... I'll give that a try !
    Sometimes, for some reason the correction tables are erratic or don't help much. If that's the case:
    You can try theses tables.
    Start by putting 2 sec. in B4606 and 4607. They have to match because the higher value will control both.
    Put 100 in 4608 and 4609.
    In 4604 put 200 from 80*C and up.
    I found the results are instant. You will likely have to find the sweet spots for your car.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Aug 2006
    Quote Originally Posted by jfpilla
    Thanks ... this seemed to have the best impact on the problem.
  1. BBL Auto Restart After Entering "Power Saving" Mode?
    By swingtan in forum Black Box Logging
    Last Post: March 8th, 2011, 09:52 PM
  2. Car Wont Idle And Runs Rich At Idle ( Tune Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 8th, 2008, 04:17 PM
  3. Have to restart V2 frequently?
    By 2002_z28_six_speed in forum FlashScan V2 BB Logging
    Last Post: December 25th, 2007, 03:41 PM
  4. Car is in OL. Stall after I stop car and restart
    Last Post: May 5th, 2007, 09:50 AM
  5. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    Last Post: July 11th, 2006, 03:58 PM
