Results 1 to 10 of 15
Thread: Still trying to get fueling there
    Mar 2004
    Default Still trying to get fueling there
    I have added a lot to the ve and it still runs with a slight chop, in the 7% throttle 2200 rpm range. It's as though there is an override preventing it from adding enough fuel. Not sure if the strategy should be cracker or follower but I am going to take them 1 at time and try to increase in small increments.
    Not sure what else to do...it's getting very aggravating and time consuming.
    2000 Camaro SS Convertible
    M6,
    LTs, AFR 205s, Comp xer 220/224, LS6 intake, Ported TB, AR TT IIs
    Post your tun file, if it's ok.
    Mar 2004
    Will do, thanks...I obviously need help and know a lot less than I thought!
    M6,
    Mar 2004
    Here ya go, I really appreciate any help.......
    Last edited by joecar; June 10th, 2007 at 07:53 AM. Reason: Reattached .tun file so it could be viewed
    M6,
    Your file's filename got truncated...
    I re-attached it for you so it could be viewed.
    Mar 2004
    M6,
    Nov 2006
    by chop do you mean lean?
    Mar 2004
    Yes, in all other areas except light throttle, 1900 to 2600 ish RPM it sound choppy - when I go into bidirectional and lower the AFR it clears right up but no mater how much I add to the VE table it doesn't get better.
    M6,
    Oct 2006
    Quote Originally Posted by DaddySS
    You mean taking away from VE , adding richen the VE thus increasing the AFR , right ? You say you lower the AFR it clears up ?
    In other words if the VE has a larger value it makes the AFR richer ?
    2006 Trailblazer
    Mar 2004
    Quote Originally Posted by tunedbyGM
    Increase VE, which adds fuel and lowers the AFR value ie 12.7 AFR is richer than 14.7 AFR.
    M6,
  1. N2O fueling.. ONLY VE?
    By Highlander in forum Custom Operating Systems
    Last Post: December 20th, 2009, 07:27 AM
  2. De-fueling at shift
    By tblu92 in forum General (Diesel)
    Last Post: November 4th, 2009, 11:27 AM
  3. Fueling questions.........
    Last Post: October 25th, 2007, 02:48 AM
  4. Over Fueling 408
    By overdrive915 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 26th, 2007, 08:18 AM
